94 civic ex
Discussion in 'Forced Induction' started by emomelodic, Aug 30, 2004.
  1. emomelodic
    emomelodic Junior Member
    boston
    hello all, i was wondering what else i will need to run a turbo on my d16
    i have a garrett t3 turbo
    20psi gateway
    greddy intercooler
    dsm bov 1g
    dsm 450cc injectors
    and some piping
    what else am i going to need to get it working right, and where can i get it?
    thanks
    -emo- :ph34r:
  2. UDT
    UDT Senior Member
    california
    Exhaust manifold? And what kind of fuel management will you be useing? And with that said how much boost on what engine where you gonna run?
  3. pissedoffsol
    a manifold, something to control those injectors like vafc, uberdata, hondata
    downpipe/exhaust stuff
    oil lines, fittings
    water lines/fittings if the turbo is also water cooled.
    and toss that gateway- thats for computers.
    get a wastegate :)
  4. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    i'm wondering why you have a 20 lb wastegate?
    built motor?
  5. emomelodic
    boston
    do you have a pref on a controller?
    and do you know where to pick up a turbo manafold, downpipe?
    turbo is oil fed. so i suppose i need to get an oil line and then a new oil pan. do i need a pump from the pan to the turbo?
    thanks
    -emo
  6. Slammed90Lude
    milford, PA
    you don't need a new pan, you just need to tap your pan for the oil return
    the oil for the turbo doesn't come from the pan, it usually comes from somewhere on the block
    IMO the sandwhich plate (that I think B is using) fits between the oil filter and block and provides fittings for both oil feed and an oil pressure sensor
    that's the easiet way to do it, since drilling and tapping aluminum blocks is no fun at all- if you're interested in going that route i'm sure B can hook you up with the link
  7. pissedoffsol
  8. emomelodic
    boston
    thanks for all the replys , awesome
    would you rather turbo a d16z6 or swap in a b18b with a gsr tranny?
  9. pissedoffsol
  10. Slammed90Lude
    milford, PA
    :withstupid:
    especially if you end up boosting down the road
  11. emomelodic
    boston
    any of you guys live around boston? and wanna help me out ? :p
  12. pissedoffsol
  13. SolLess16
    SolLess16 Senior Member
