Hey i got a 94 civic hatch 5 spd. with no engine and tranny. I'm thinkin about doin a gsr swap in it. I'm prolly goin to order my engine from hmotorsonline. I am wanna know if this is all the things i need:
- Motor
- Hydrolic Tranny (S80, Y80)
- ECU (P72)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
Um... what's the differance between the two different kinds of transmissions (S80, Y80)?
thanks a lot
- Motor
- ECU (P72)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
thanks a lot
