94 Civic Hood Wont Open
Discussion in 'Civic and del Sol - EG and EK' started by 91integra91, Jan 24, 2008.
  1. 91integra91
    91integra91 1# shifter
    GTA/ONTARIO/CANADA
    well my buddie has a 94 honda civic si coupe. His hood wont open, the resason before it wouldent close lol.....so we cleaned it and we hooked the wire around the close hindge but we forgot to put it around the open hindge part.....so now it wont open lol anyone know how to open it the hood?????????????????????????????
  2. 91integra91
    GTA/ONTARIO/CANADA
    i was thinking to go behind the front fender or put the car on jack's ANYONE?????
  3. dacheat
    dacheat ..is grounded.
    strongbadia
    you should be able to yank the cable from the back of the hood release inside the car. or, if your car is like my rex, you can grab the cable in front of the rad grill with a finger and yank it. as for why your hood wouldn't close before, likely has to do with the hood catch needing to be adjusted.
    if you're saying you guys pulled the release cable and it isn't attached to the hood catch assembly any longer, i'm not sure you can be helped; you'll likely have to pull the bumper and try to manually release the catch.
  4. norcalgsr
    NorCal
    Yeah sounds like you're going to have to pull either the bumper or grill, or both, and manually move the latch to pop the hood open. I've had to fix a couple cars like that where the hood latch cable wasn't working, and I pulled out the grill to access the latch assy. and popped it open manually.
  5. Discoshit
    Discoshit New Member
    I Thought The Latch On My 94 DX Was The Problem, But It Turned Out If I Just Manually Pushed The Cable Over From Under The Hood, It Would Close Fine. There Are Two Springs In The Latch, And So Far, Both Times It Been The Lower One That Needed Replaced. You Should See On The Lower Left Side Of The Latch Where The Cable Comes In, Just Try Pushing It To The Right, And It Should Close Fine.
    As For Opening It, If Pulling The Cable From The Rear Of The Interior Latch Didn't Do The Trick, I'm Afraid They Are Right, You Might Have To Pull The Bumper, Which Is Attached With four Bolts Under The.... You Can Guess It... Hood. The 94 Civic's Don't Have A "Grill", So You May Have To Remove The Crappy Plastic Wheel Well On The Right Side, Or Try Reaching Up Through Behind The Bumper.
  6. BrutalB83
    Rochester Hills, MI
    Check the dates on shit before you post dude. This thread is three months old...I'm sure he's probably figured it out by this point...
  7. dacheat
    strongbadia
    brownie points for the helpful noob though :thumbsup: -- is far better than the noob of bullshittery.
  8. BrutalB83
    Rochester Hills, MI
    True, I will give him that. At least he didn't bring it back for some incoherent, barely legible, ghetto-speak-laden waste of a response...
  9. jastreb
    jastreb New Member
    or for...
    those of us who have the same problem two years later and googled a solution, I found the response very helpful
