94 civic with 99 ex motor
tomogchi
Hello all; Got a quick question for you all.
I just finished a d16y8 swap in my civic. All wired up (minus for ecu; and my d15 distributer is modified to work at this exact moment).
Other than that, I have spark, and i have excellent fuel pressure coming upto the fuel rail, and in it even. But the injectors will not pulse to give the motor fuel. There is voltage in the injectors, and i know they work, because they're off of my d15 aswell.
Any ideas as to why i cant get this thing to even attempt to run? Is there a way to temporarily jump the injectors?
Thanks,
Bill
injectors
are you sure there's no pulse, did you use a noid lite?
maybe it has a bad ground, if you jump them make sure no wires are going to the ecm, use a 9 volt transistor battery and connect one wire and just tap the other to the post. DON'T CONNECT BOTH WIRES SOLID
