D desdog Junior Member Sep 26, 2003 #1 Friend has a 96 Civic with a blown engine. Also has a 94 Civic with a D15B7. 96 is a manual 94 is an automatic both are non vtec How do I get past the ECU changes? can the 96 ECU just plug into the 94 engine and work just fine or what?
saturn_boy96 88 C1V1C 53D4N DR1V3R Sep 26, 2003 #2 i think you can do the swap, but you will need to use the '96 intake manifold, throttle body, injectors, and wiring harness. but if you could figure out how to use the '94 intake manifold i think its better for top end performance.
