'94 Del Sol Powered By '98 Integra Ls
denseljr
I have a 94 DelSol, with a '98 Integra LS in it... It has a Clutchmaster Stage 3 Clutch and a flywheel. and a high flow Cat. And i has a LS fuel pump, and a Air/ Fuel controller. It only has 79,987 miles on it, i want it to be a daily driven car. I also has b16 pistons, but are not in, I DONT WANT LS/VTEC!!!
Can Someone Help ME OUT!!!
boost is the way to go. but if you're going to turbo it, you don't want those B16 pistons in there.
i don't even know if B16 pistons will work properly with your stock LS. anyone???
the B16 pistons will work (bill has them in his)
do you want to go FI or NA?
headwork!!! get the thing flowing, some new valve train and larger cams, and you'll put 150-160 horse to the wheels no problem
Ya, i want to do N/A, i didn't want turbo.... I have an LS tranny, what valve springs should i get and what cams?? I would like to spray it, but i dont want it to blow up!!
nitrous is not N/A
but anyway
go with some crower 403s with a crower spring set
