94 delsol modded worth the price?
Discussion in 'Civic and del Sol - EG and EK' started by AURMEND, Jul 3, 2011.
  1. AURMEND
    AURMEND New Member
    hi im about to buy a 94 honda delsol si for $3400 cash and i wanted to see if it was worth it this is what he said it had.
    The shell:
    its an si with neuspeed suspension droped on lowering springs, it has white slipstreeams with toyo tires,it comes with hids,racing stearing wheel,tinted windows,clean interior,new breaks all around,type r lip,2 1/4 piping,
    The motor:
    its an lsv with less then 3,000 miles on it,it comes with acl race bearings, jdm type r pistons,type r oil pump and water pump micropolish cranck,its has a b16 head (pr-3) with supertech valves valves springs 2 angle valve job port and polish with itr cams.new starter and alternater new belt also,gsr fresh tranny with act stage 2 clutch kit,
    car runs great .the top dont leak it rides smooth it has a jdm p30 vtec pops at 6k revs up to 8500
    is thier anything that will go bad on the engine setup
  2. AURMEND
    AURMEND New Member
    also if i were to buy lets say an intake what make and model should i put it as 94 delsol si or what ever the engine is
  3. AURMEND
    AURMEND New Member
    he texted me and he said
    this its1995 acura integra block with aftermarket internals with 2000 civic si head with a 2000 acura integra gsr. and the motor is a 2.0
    idk what he means in this part " with a 2000 acura integra gsr"
  4. 95b16coupe
    95b16coupe New Member
    ct
    if it has a clean title and runs well, and the body is straight, it's worth it. but i wouldn't buy it without a full inspection from a legit shop. it would be worth the $150 to get a thorough inspection.
  5. monotech
    monotech Member
    $3400 is cheap if it's a clean title with LSV swap. The suspension sucks but can be replaced later on. Check compression on that swap and see how healthy it is.
    Good luck
  6. rhymeshark916
    rhymeshark916 New Member
    Sacramento, CA
    I would tell him to get it dyno along with a compression test.. Without it, I wouldn't buy. Running a P30 map with a hi-comp built motor is asking for disaster. SMH. I wouldn't even drive it without a P73 map at the least.
