94 EG hatch...with rear disc brake conversion...?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Hondatuner88, Aug 11, 2005.
  1. Hondatuner88
    Hondatuner88 Senior Member
    Hey guys, I just swapped a set of rear disc brakes into my hatch..But i think there off a EG coupe..The ebrake cables dont reach...My question...is how can I tell what car they came off of? They bolted right up tho. Any help would be a huge plus!!!!! Thanks!!!
    Koby
  2. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    So you say the brakes are off of an eg? Si had rear disc, what car are the brakes on?
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Your stock ebrake cables won't reach on disk brakes. You've gotta get ebrake cables from a car that came with rear disks, such as a 92-95 Civic Si, 90-up Integra, or 99-00 Si.
  4. endlesszeal
    endlesszeal Senior Member
    Del Sol Vtecs, Si Hatchbacks, and Si coupe. Oh yeah, most definately Type-R
  5. Hondatuner88
    Hey, Thanks guys...now this is prolly the dumbest question in the history of hondaswap but....How ezactly do I get the ebrake cables off and back on...Looks really tight up in there...someone pleaseeeee help!! And do you's think I need a bigger master clyinder?? If so...what should I swap on there? THANKS everyone!!!
    Koby
  6. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    i took my exhaust off and some heat shields to get my cables off and then on. im not running a different mc and i have integra brakes all around. i did add a 40/40 prop valve though which i recommend.
  7. Hondatuner88
    What intregra brakes you running up front?? They bolt right on?? Can I upgrade out of a junk yard?? What will I need??
    Thanks,
    Koby
  8. vtecsir1
    Orlando, FL
    94-01 integra, front spindle is the easiest way to go. shouldnt cost more than 150 from a junk yard and you can use abs or non abs doesnt matter just take off the abs pieces if you have them. everything bolts up fine but make sure to get them off a newer teg because you dont want shot bearings. prop valve can be had out of a non abs rs model integra or older model teg.
