94 ex CD Help
Discussion in 'Car Audio / Security / Electronic Accessories' started by Whitt, Dec 13, 2008.
  1. Whitt
    Whitt New Member
    First off ive installed a dozen cd players in a dozen different cars but this one has me.... I have a 94 ex coupe and it came with the tape deck and cd player and it asks for the security code .... well after removing the factory tape deck and installing my new cd player when i wired it all up everything worked had sound to all my speakers ..... well turned the car off the next time i started it cd player is on but no sound what so ever so took everything out re wired same hting happened no fuses blown .... is there a way to by pass the factory security speaker lock on them?!?!?!
  2. eg6sir
    security speaker lock????? riiigght
  3. Whitt
    Whitt New Member
    yeah the factory tap e/cd player when battery is disconnected or loss of power it asks for a security.. it locks up the radio ...
  4. MthaFuknGreen
    Lodi, CA
    i think its one of those funny things you say about cars..
  5. neonmike
    neonmike Senior Member VIP
    there is no such thing as speaker security lock, it is a security for just the radio. if you put in a new radio and it works then doesn't it is either a) you have a short in one of your connections or b) you have a blown speaker which is causing the radio to go into a protect mode which is a safety so you don't fry the radio. check your connections if no bare wires are touching then you have a blown speaker somewhere.
