94 civic ex
212xxx on body\
just pained 4-14-06 black blue pearl
b18a1 not broke in yet 700 miles on it
bored 20 over 10:5:1 compression
je pistons
eagle rod & crank
3 angle valve job flow port
3mm bigger intake manifold
new everthing in the head
stage 2 crane cams
dc sport header
msd exteral coil and dist.
everthing brand new on the block even o rings on water tube
u name it it waz done
prefesonally assembled
act street strip clutch
new axels
acl bearings
oil presssure gage
450cc eclipe injectors with 10ohm 10watt resitors
computer is being chipped right now
wamlbro 255 fuel pump
b&m fuel pressure regulator
thinking about selling just want opiniom what to ask 4 it i have about 8500 in it
not sure what to ask 4 it
212xxx on body\
je pistons
eagle rod & crank
stage 2 crane cams
dc sport header
new axels
acl bearings
oil presssure gage
