94 Gsr Vs 99 Gsr
Discussion in 'HYBRID -> EG-EK / DC' started by BrowNKiD, Apr 24, 2005.
  1. BrowNKiD
    BrowNKiD Member
    Toronto, Ontario, Canada
    I know the differences between odb1 and odb2. I know that if i drop a odb1 gsr motor into my hatch it is a direct bolt in change nothing. But if i bolt a odb2 gsr motor into my hatch and use the odb2 harness and plug it into the shock tower do i need to use a odb1 dizzy and injector?
  2. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
  3. BrowNKiD
    BrowNKiD Member
    thx that help A LOT but it also brought up one more question. a p28 doesnt have a knock sensor. when u get it program can u get one programed in? of do i not need to worry about the knock sensor. how important is the knock sensor?
  4. civiclxb16
    Poconos pa
    no you don't get to worry about the knock sensor i am running a chipped p28 on my b series engine and it does it pretty well. if you get a p28 make sure you get it chipped to run the dohc aight man have fun with it
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You don't need a knock sensor, if you use the OBD II harness, you use the OBD II parts.
  6. civiclxb16
    Poconos pa
    basically that sums it all up dam i should of thought of that(thats why he has 10000 postings...lol)
