kurruptmetal
Hello i have a 94 si del sol that the temp sensor in the motor went out and super heated my motor. well it smokes horribly now. 2 diff mechs said it's hosed. as a result i found your site and have been reading and reading.
Houston, texas has a few shops that do swaps and so far here's what i am thinking about getting from ebay to add to the engine swap.
any other help or things i need to have and take to the mechanic for the swap would most apprieciated.
B16A
chip your current ECU to run DOHC VTEC
cannot run same drive shafts or shift linkage, you need axles and shift linkage
Exedy and Fidanza clutch
flywheel Toda 8.8lb chromoly flywheel
header
intake
• Complete Motor
- Block
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Starter
- Alternator
- Ignition Wires
- Headers
• OBD2 ECU (Computer)
• 5-Speed FWD Hydraulic Transmission
- With Clutch components assembled to the engine
• Intermediate shaft
• Axles
• Shift linkage
ebay parts:
B16a B18c5 Civic/Integra Race 4 - 1 Header
eBay Motors: B16a B18c5 Civic/Integra Race 4 - 1 Header (item 370022353137 end time Feb-18-08 17:30:09 PST)
WINFAB TUNING Honda Civic JDM P08 P28 P30 ECU Chip B16A
eBay Motors: WINFAB TUNING Honda Civic JDM P08 P28 P30 ECU Chip B16A (item 160143269122 end time Feb-26-08 11:25:40 PST)
EXEDY RACING STAGE 1 CLUTCH 94-97 HONDA DEL SOL B16A
eBay Motors: EXEDY RACING STAGE 1 CLUTCH 94-97 HONDA DEL SOL B16A (item 180212739062 end time Mar-03-08 21:56:05 PST)
Civic Del Sol Air Conditioning AC Bracket for B16A swap
eBay Motors: Civic Del Sol Air Conditioning AC Bracket for B16A swap (item 110224362704 end time Feb-18-08 16:04:35 PST)
NGK Iridium Spark Plugs Heat Range Turbo B16A B18C
eBay Motors: NGK Iridium Spark Plugs Heat Range Turbo B16A B18C (item 270211526208 end time Feb-19-08 17:33:05 PST)
88 91 CIVIC CRX B16A NEW cv axles drive shaft B16 B18
eBay Motors: 88 91 CIVIC CRX B16A NEW cv axles drive shaft B16 B18 (item 120221867609 end time Feb-19-08 20:35:10 PST)
HPS Air Intake Kit Honda 93 94 95 96 97 Del Sol S Si
eBay Motors: HPS Air Intake Kit Honda 93 94 95 96 97 Del Sol S Si (item 190198192230 end time Feb-18-08 17:02:51 PST)
TOKICO HP Shocks struts Civic Del Sol 94 - 01 Integra
eBay Motors: TOKICO HP Shocks struts Civic Del Sol 94 - 01 Integra (item 370022639442 end time Feb-22-08 16:14:52 PST)
B16A
header
intake
• Complete Motor
- Block
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Starter
- Alternator
- Ignition Wires
- Headers
• Axles
• Shift linkage
ebay parts:
