94 integra b20 build requirements help help!!!
redrockracer
hi i am building a 1994 integra b20z2 engine block with a b18c1 vtec head, i have a couple of questions for the build the first one is which harmnic balancer do i use the b20 balancer or the b18c1 balancer? the next one is i know that the oil line conversion has to be done and the the b20z2 bottom end has to be built with arp main bolts arp rod bolts and arp head stud kit i also did acl race bearings all through the bottom end is there anything else i need to do or watch out for when i do the conversion? please help i have built several honda motors and conversions this is my first b20vtec thanks
Use the B20 crank pulley since you are using a B20 bottom end and crankshaft. Ideally, you'll use the one that came with that engine from the factory.
As for things to watch out for, just follow the same steps as an LS-VTEC. They're essentially the same builds.
