Get this, wired in the motor, double checked the pins to the ECU, all mechanichal connections made correctly, and it's all screwed up. Connected the battery without the key in the ignition and the tach and speedo (Auto Meter) lit up. Put the key in and turned to accessory, pushed the clutch in and the starter engages without turning the key to start. Turn the ignition off and remove the key, Turned on the headlight switch and the starter engages (no key or clutch). Then nothing happens and the car is dead. Have a blown alternator fuse, starter fuse, and right headlight motor fuse. PLEASE HELP!!!!!!!!!!!!!!
