if you want high 200 or in the 200 range you can use dsm 450cc injectors but since your car is a 94(or i'm assuming) you will need to run a resistor box with it....a 60 trim turbo is just fine...for you hp range...track numbers? thats all dependent on varies things etc traction, driver, tire pressure...you can piece a reasonablely good honda/acura turbo kit for about 1000 consider using a few use parts and with patiences...good luck guy....
