94 LS Wont Start...Help
Discussion in 'General Tech and Maintenance' started by ef9civicgen4, Feb 3, 2005.
  1. ef9civicgen4
    ef9civicgen4 Senior Member
    Independence MO
    its a 94 integra ls with zero mods. we were driving it a half an hour before it died. then we parked it for 20mins or so then we started it and made it up the street, then when we took off it bogged really bad, and died moments later.
    there were no odd sound. we have a strong spark and its gettign gas, the pump is kicking on, the plugs are new...but still no fire. im lost guys...someone help or suggest something.
  2. Punisher
    Punisher Member
    Failing igniter module? Same experience once, had to call tow. The rpm needle also acted up with it.
  3. ef9civicgen4
    Independence MO
    well we have a grs dizzy we swapped eveything out of. then we checked to see if we had spark, and we did. so we have spark and fuel, but she wont start.
  4. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    I also had a similiar problem. It turned out to be two things. Dirty fuel lines and filter was the bog down problem. The starting problem turned out to be the starter.
