ok heres the deal i put a 1996 accord f22b1 VTEC in my 1994 accord non vtec...i got the motor in and the ECU i had to use a "jumper" cable because i was going from a obd1 to obd2 but now im throwing VTEC solenoid code, ELD, misfire,and automatic transaxle codes..the motor was an automatic i put on the 5speed my car revs out at 5000RPM and has idle problems when i unplug the VTEC the idle problem stops but still revs out at 5000RPM im totally lost as of this moment i need ideas etc. im ordering a new VTEC solenoid and getting new fuse box tomorrow
