94civic.2dr.dx.b16a2swap.need help
civictuner07
i have a 94 civic 2dr coupe dx, with b16a2(from japan) swap,only having problems with engine wiring harness, car is LH drive, harness is RH drive, i aparently have to to swap the main connectors (on harness side) to firewall from left to right and right to left but have no wiring diagram for saftey, does this make sense to anyone, the ecu is a p28, it plugs right in no problem, its just the engine harness i am having questions about. does anyone have any good ideas or comments that would be useful? P.S. the car and the motor are both OBD-1 or atleast they should be.
use your cars stock wireing harness for the b16 motorthen just run a few wires for the vtec
