fastacc
Doin work!!!
I just finished up my accord build when I realized that I have wheel studs missing on every wheel. I mean just one on every wheel. I really just need to get the outer hub off so I can replace the studs as the rotors are fine. I pulled the 4 bolts that are on the wheel side of the hub. I have assorted pullers and whatnot. Is there any other bolts I am not seeing as this bitch will not seperate. I removed axle nut and was wondering if I positioned a claw puller between the outer hub and rotor will it come loose. I just dont want to F#%k anything else up to get it off. Any help would be appreciated,thanks
