95 accord overheating
Discussion in 'Accord' started by Cd5love, Nov 8, 2010.
  1. Cd5love
    Cd5love New Member
    My car keeps overheating I already replaced the thermosat and the water pump once the temp in the gauge stays at normal but when I open the hood I can feel it way to hot I have no idea what it could be. Does anyone?
  2. elgwedoloco
    elgwedoloco New Member
    Headgasket maybe? look for oil/coolant leaks off the block and start there.
  3. Cd5love
    Cd5love New Member
    I already replaced the head gasket I also just cracked the radiator from pressure build up so idk what to do other than to replace everything
  4. 94H_Ex
    94H_Ex Under employed
    Florida
    You need to explain the details of your problem alittle more. Your gauge is reading normal, but its "too" hot according to you. You've already replaced the water pump, head gasket, and thermostat. Plus now your radiator cracked from too much pressure? All according to you of course.
  5. Cd5love
    Cd5love New Member
    My bad just not used to askin people for help i do all my own work I found out it's just the problem my radiator was completely clogged up and thermostat was stickin just to Many probs
