I have a 95 accord that will start and idle "cold and act completely normal through all rpm's. as soon as she gets up to op temp the engine will idle down significantly when any accessories are switched on, also it will stall out when the clutch is pressed - accessories on or off. again it acts completely normal until the engine reaches op temp. I have swapped out the iacv with 2 others and no change whats so ever, also fuel pressure is good. i have seen many simular posts but none exact to my symtoms. dose anybody know this problem??
