It wouldnt fit for me.. it fit 180 backwards on the cam and didnt fire the right order... the one from the 95 i got was td46u and the obd2 one is td85u.. so they were different... i got it off ebay from a guy parting out a 95 ls he said... i just got the obd2 one and had to splice and soldier cause when i pulled the wires from the plugs they wouldnt fit in the plug from my obd1harness they were alittle to big.silva95teg said:the obd1 b18b dizzy is the exact same as the obd2 b18b dizzy except the plugs are different. they have the same parts numbers on all the components inside too. ^^^^^ Are you sure it wouldnt fit if you turned the dizzy shaft 180 degrees?
Where the fuck are all these dumbass noobs coming from? A non-vtec distributor will NOT fit on a vtec head without bootlegging it....turning the distributor shaft 180 degrees wouldn't make a shit of difference seeing as the housings are different...silva95teg said:the obd1 b18b dizzy is the exact same as the obd2 b18b dizzy except the plugs are different. they have the same parts numbers on all the components inside too. ^^^^^ Are you sure it wouldnt fit if you turned the dizzy shaft 180 degrees?
civicious said:Where the fuck are all these dumbass noobs coming from? A non-vtec distributor will NOT fit on a vtec head without bootlegging it....turning the distributor shaft 180 degrees wouldn't make a shit of difference seeing as the housings are different...
As far as which distributor to use, use the same OBD or newer distributor as the ECU that you're using...i.e. if you've got an obd0 ecu you can use an obd0, obd1, or obd2 distributor; if you have an obd1 ecu you can use an obd1 or obd2 distributor; if you have an obd2 ecu you can only use an obd2 distributor.
If the distributor is a different OBD than your car, you'll have to rewire the distributor plug, but this is a simple color-matching process.
edit: on another note, if your problem is that it's firing in the wrong order, you have your plug wires on wrong.
silva95teg said:Hey bud .... this "noob" as you call me is comming from canada .... and i was reffering to the post above mine which had nothing to do with vtec period.....it was b18B into b18B. And as far as the b18b dizzys go i have both a 95 and a 2000 sitting here and i just had both apart and they are identical internally..... the 180 degree thing i was referring to is because on the b18b it looks like it could go in two ways, but one one of the two ways will it go right in .... hence 180 degrees ... once again directed at the poster above me.... so you can keep your "dumbass" comments to yourself thanks.
I'm not seeing where he asked any questions, and I'm sure as hell not seeing the relevance in your post to his. His distributor didn't fit because the plugs on OBD1 and OBD2 distributors are different...but hey, look at this! He fixed his fitment issue by soldering different plugs on it!Im not sure if the obd1 gsr dizzy is the same as the odb2.. if i were you i would use a obd2 gsr dizzy beacuse thats what year the head is and thats where the dizzy goes(camshaft in the head).. I bought a 95 b18b dizzy for my jdm obd2 b18b and it didnt fit.. i had to buy another obd2 dizzy and soldier the wires... wasnt hard just a waste of money for the other dizzy that didnt fit.
...which are all sensors that are vital to the car's operation.silva95teg said:so the only thing that could be different are the tdc,ckp, and cyp sensors.....
FuCoSPD said:so use the dizzy from the obd2 gsr and splice the wires from the one big plug used on a obd2 harness to the two littler plugs on the obd1 harness and be done with it.
vtecsir1 said:or rewire any obd 2 b series vtec dizzy
Cause you said OR rewire an obd2 dizzy... if im not mistaken an obd1 dizzy wontfit on an obd2 head. Just what ive learned from previous experience.vtecsir1 said:too bad i fucking said this like 3 weeks ago so whats the point of saying it again?
