95 civic auto dropped b16a jdm obd1 to obd2 ecu
Discussion in 'HYBRID -> EG-EK / DC' started by JDMAutoFlapper, Jan 5, 2017.
  1. JDMAutoFlapper
    JDMAutoFlapper New Member
    Looking for information, hopefully this isn't to complicated , dropped a b16a jdm civic sir dohc engine into my 95 civic ex, currently usen the original a/t wire harness from the 95 , and p28 ecu original , trying to slap my obd2 p2t oem b16a jdm sir civic a/t ecu, looking for conversion adapter or any info would help , Thanks
  2. E_SolSi
    your best bet will be to simply chip the P28 (or get a chipped P28) or if you can find one and want to spend the $$$ you can try to get a P30 (OBD-1 B16 ECU)
    running the P2T can work but you will have issues with a lot of the OBD-2 sensors and whatnot not being there, you could potentially chip that ECU to turn off several of those sensors (maybe??) but by this point you could have simply went with a P28 and not had to bother with all that crap
    as for conversion harnesses - http://www.rywire.com/ecu-jumpers-s/1824.htm
    everything is possible (even when not recommended)
    2 Door Ek Nasty likes this.
  3. Briansol
    is your b16 still auto, or did you do manual conversion?
