I have 95 civic swaping in a b18a. When I am doing my wiring for the new engine. will the b18a computer plug up to my car. Can I use my old harness. What is required other than ecu?
Obd-1 Distributor Ls for proper fitment.
92-93 Integra Pr4 Obd-1ecu or 94-95 Integra P75 Obd-1 ecu.
change the injectors to Obd-1 to prevent from having to rewire your injector pigtails and using Obd-0 injectors with resistor box. Make sure you keep the 4 wire o2 sensor depending on the civic model you have either way you need to use 4 wire o2 sensor.
Radiator fan plug will need to be relocated to the back of the motor next to the oil sending unit.
