95 civic b18b swap Starting problems
Discussion in 'HYBRID -> EG-EK / DC' started by Mild95Eg, Feb 24, 2011.
  1. Mild95Eg
    Mild95Eg New Member
    hi i have a 95 eg auto with a b18b auto and i have the motor in and hooked up but it just wont start. it just cranks and wont fire. i checked theres fuel and spark and the timing is good. what could this be?
  2. CharlotteS14
    CharlotteS14 Ninja Chimp
    Cameron, NC
    Did you have fuel and spark when you first attempted to crank it? If you had fuel and no spark at first you may have washed out the cylinders with fuel. (flooded) If the engine is flooded remove all 4 spark plugs, remove fuel pump relay, and turn over engine several times to exhaust fuel from cylinders. Reinstall spark plugs, and and relay and attempt to crank. If this does not work, check your compression and see if you have good numbers across all 4 cylinders. (this is based on the statement that you have verified timing, spark and fuel)
  3. 95dc4iwantoboost
    95dc4iwantoboost Boost Envy
    Sacramento
    Agree. If this doesnt work, Make sure you have good fuel pressure. If you dont, its not going to run either.
    From there, its to spark, and thats self explainitory, just dont use your tounge to check it.
    Last, check to make sure your timing belt didnt jump a tooth or two. This also will be a cranking nostart.
  4. Mild95Eg
    Mild95Eg New Member
    i forgot to mention it was running before i pulled it out of the integra and put it in the civic. but ill try pulling plugs and fuel pump relay and see what happens
  5. Mild95Eg
    Mild95Eg New Member
    hey i tried pulling plugs and relay didnt work so i checked compression and its good. so im stumped i have no clue i tried everything.:( Could it be ignition timing? and can i check that with out it running?
  6. Fernpatch
    Fernpatch Member
    Bellingham,WA
    does it spit, pop, bark, or do anything besides just crank over?
  7. krz12
    krz12 New Member
    hey if no luck yet make sure all ground cables are hooked up i say that cus it happened to me b4. also i am new to the whole forum thing, can u guys tell me how i start a new post?
  8. Mild95Eg
    Mild95Eg New Member
    no it doesnt do anything but crank over. it sputtered once but that was it
  9. Mild95Eg
    Mild95Eg New Member
    it should be just the tranny ground and theground from the valve cover to rad support right?
  10. hondafreak513
    hondafreak513 New Member
    O hi O
    There is a ground for the ecu on the thermostat... But it really sounds like the spark plug wires are not in the right order...
  11. krz12
    krz12 New Member
    yea but if they werent in the right order it would at least start and just run like crap
  12. Mild95Eg
    Mild95Eg New Member
    is the ecu ground ran threw the harness that plugs in on the strut tower? cause it hooked to the thermostat
  13. krz12
    krz12 New Member
    the most simple things are always overlooked. have tried jumping it?
  14. CharlotteS14
    Cameron, NC
    If you have spark, fuel, and compression it should at least do something. What were your compression readings?
    I do not understand how it could be a ground problem if it has been verified that there is spark and fuel. check it anyway.
    Reason I mentioned flooding earlier is because I had a car at work that came in with a bad coil. The owner flooded it out real bad before bringing it to the dealer. I put a new coil on it and turned it over what seemed like forever before it even fired once. I thought I misdiagnosed it. annother tech at the dealer said keep turning it over untill it starts or the starter burns up. It started ater cranking it for over a minute. smoked like hell but was fine after warming up. sounded like it had not compression before it started ie washed out cylinders
  15. hondafreak513
    O hi O
    Not true at all depending on which way they are hooked up it will just crank and crank... And the ground on the thermostat does run through the tower plugs it has about 6 black wires on it just make sure it has a clean connection..
    1 person likes this.
  16. Ethan
    Ethan Well-Known Member
    not true! i had a similar problem.. check them 3 more times! when i screwed up it cranked and didnt give a pop or stutter! NOTHING AT ALL!
    /ThumbsUp
  17. Mild95Eg
    Mild95Eg New Member
    well i triple checked the plug wires all good and cleaned the ecu grounds and cranked it for a while still nothing
  18. hondafreak513
    O hi O
    Spray some starting fluid in it see if that gives it a boost...
  19. Mild95Eg
    Mild95Eg New Member
    well i triple checked plug wires there good and cleaned the ecu grounds and cranked it for a while abd still nothing
  20. Mild95Eg
    Mild95Eg New Member
    could it be ignition timing out? and could it be set if it doesnt run?
