95 civic b18b swap Starting problems
take line off the at the fuel rail and see if theres fuel getting to it when u try to crank it. pretty sure u kno but point the line at a rag or something so it doesnt spray evrywhere
get a noid light, see if you are getting signal to the injectors... you casn have all the fuel pressure in the world, but if nothing is telling the injectors to open and close, it will never fire... what distributor are you running? if the wiring from the distributor to the ecu is incorrect, it will not get the injector pulse signal, and will not run...
everything is good just drain some fuel and wouldnt you know its a green color. the wife i geuss put deisel in the tank instead of gas.
