95 civic dx swap question
i recently got a 95 civic dx couple with a 94 b18c1 gsr motor. The ecu currently is a p28. It was not wired for vtec so i wired it according to the pinouts. Is this the wrong ecu for the car? do i need the obd1 gsr ecu(p72) or what should i do to make it work properly. I do have a skunk2 manifold but it is not currently installed on the car. It is a project that i am trying to make run properly. Any help is greatly appreciated
it will run and drive off the p28, the p72 lets you use the IAB's if your using the stock intake manifold
