I removed the 8 valve/5 speed drivetrain from my 95 cx Hatch. Installed the complete b18b1/5 speed drivetrain from a 95 ls Integra. I drove both vehicles before the swap so I know they both worked flawlessly . I swapped in the p75 computer from the Integra. Everything is connected. All wires hoses and plugs are connected. I can hear the fuel pump turn on when I turn the key on
No spark. The new ngk Spark plugs are pretty dry so I'm pretty sure the injectors aren't firing. Any ideas? Is the cx civic wiring harness different? I was sure this swap was a plug and play. Every part of the installation went great. All it does is turn over,but will not start.
Any ideas?
EDIT: fixed, see post #15
Any ideas?
