95 Del Sol mess
Discussion in 'Civic and del Sol - EG and EK' started by doobie60, Apr 22, 2011.
  1. doobie60
    doobie60 New Member
    Bought a 95 Civic Del Sol whicch has a D16Z6 VTEC engine swapped by a previous owner. Running real rough at higher RPM's and going through gass like crazy. Trying to find out what model this thing came out of, local Honda dealers no heelp. Do I neeed to swap out the ECM and wiring harness. Any help would be greatly appreciated.:confused:
  2. E_SolSi
    the D16Z6 is the engine that came in the 93-95 del sol si as well as the 92-95 civic si and ex
    it uses the P28 ECU
    what model del sol do you have?
    in 95 there was the S, Si, and VTEC
  3. doobie60
    doobie60 New Member
    According to the Vin# it'a an S
  4. doobie60
    doobie60 New Member
  5. E_SolSi
    wire up the VTEC and put a P28 in there
    should be about as direct of a swap as possible
