95 delsol vtec wire up
delsol_racer
hey i have a 95 honda del sol with too many miles on it
1 question is how do i find out if its a obd0 or obd1 with out looking at tha ecu i forgot
2 im getting a d15 vtec motor like in 2 weeks and i need to know which wires i run from tha ecu to tha vtec i know i have to change tha ecu i have it so all i need to know is where to get a digram or something to show me which wires to run
and i did search for it but i couldnt find what i was looking 4
thank you
Twitch
well your del sol is obd1, and just run the vtec wire to the propr pin out on the ecu,dont for get the pressure switch also, there pics every were of ecu pin outs
cool thank you where do u reccomend a place i can find cuz i dont know if im just not looking in tha right spot or what but idk im not sure
well what ecu are you gona use the p28 or the po8
all i have to wire up is tha vtec siloniad and tha pressure switch
i thoguh i read somethign bout a knock sensor but i think its alrady wired up with tha stock motor cuz there both d15's
