95 Ex Idle problem
Discussion in 'Civic and del Sol - EG and EK' started by 95Dvr, Nov 17, 2009.
  1. 95Dvr
    95Dvr New Member
    Oh
    My 95ex has been idling between 1k-1.5k and reving on its own, somtimes higher or lower rpms but always in the same range jumping 500 rpms or so. I've replaced the idle air control valve based on my brothers advice but it hasn't fixed the problem in any way. Just wondering if anyone here has come across this problem or knows what might be acting up on the car.
  2. Briansol
    Check/Bleed the coolant system. an air bubble will cause odd revs.
    Check the TPS set screw on the back of the throttle body, it might just need to be turned down.
    Check the throttle cable, that its not twisted and tb can fully close.
  3. 95Dvr
    95Dvr New Member
    Oh
    Thanks for the help B, I'll get to work checking everything out
  4. pooksy64
    pooksy64 RidetilldeathdousparT
    HOUSTON tX
    ---due to fast idle valve. check the adj screw. i mentioned this same prob in another thread
