95 ex trans problem
fastacc
Doin work!!!
Recently I put my coupe back together so I'd have a good comfortable car for my newborn daughter to ride in. I installed a jdm F22b and a 5spd out of a 95 LX. I used a Fidanza clutch, flywheel pressure plate and throwout bearing. About a week ago I noticed the pedal feel was a little weird. It got worse and the clutch was engaging when the pedal was about 1/2 inch off the floorboard. I bled the slave cylinder and no air. After that I couldn't get it into gear while running. I killed it put it into reverse and it tried to slightly roll while running. I ended up replacing the slave and master cylinder. That seemed to make it worse. Now it tries to roll hard when started in gear. Any Ideas?? I have bled this system for at least an hour and I filled the slave before I installed it. Pedal is extremly mushy and I cleaned out all clutch lines. I'm out of ideas.:confused::confused::confused:
