Sorry for the repaet questions and semi double post..kinda goes in hand with the ECU question..I have searched this up and down..most swap info is geared towards f22b1 into earlier model accords..
so far it looks like if i had too, i could swap the egr's so it will mate with the f22b2 harness..
the internal coil dist , i have still yet to find info......should i just put the ext coil on ? I thought i found a couple posts that mention the internal coil had to stay with the v tec swap....
i may even consider grabbing the harness from the donor car(94EX auto) that supllied this ecu, ..just not sure how hard it is or possible at all with the dash and hvac system in place(firewall harness)
Thanks
Thanks
