95 gsr engine, into a 92 civic hb
Discussion in 'HYBRID -> EG-EK / DC' started by indeskater, Mar 28, 2004.
  1. indeskater
    indeskater Member
    i'm going to put my b18c1 from my gsr into my 95 civic si.
    can i use my factory si wireing harness?
    will i need any xtra wiring?
    will my apex exhaust bolt to the factory b18 manifold?
    should this be a pretty simple swap?
    what should i watch out for?
    ps. i'll get u guys some pics of the swap.
    thanks
    Justin
  2. slowhatch95
    slowhatch95 Junior Member
    yea u can use the stock harness, u MAY need extra wiring...im not positive, your apex exhuast goes all the way to the header? if it does just measure piping size and make sure the bolt holes will line up. I think it should be pretty simple, but dont qoute me, im still tryin to figure all my shit out
  3. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
  4. GSRTURBO
    GSRTURBO Member
    actually i have a question about the hasport mounts. this is for a 98 gsr into a 95 coupe. under the swap section, it says i need the EGB1 mount kit. (which is what im pretty sure i need.) however, when i go to the shop online section, go to 92-95 civic with an integra swap, the mount kit that says i need is the DCSTK. i was a little confused by this????
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You should make your own thread. But anyway, the reason is because some of the later models use a vertical driver side mount, and some use a horizontal mount.
    Horizontal...
    Vertical...
    SO depending on what car you're putting it in, you have to get the right mounts
  6. b16ahatch
    b16ahatch Senior Member
    I thought they only used the viertical mount on the 6th gen civic. I didint think they were on the 5th gens.
  7. GSRTURBO
    GSRTURBO Member
    sorry for the thread jacking, but which kit has the horizontal mount? The egb1 kit or the dcstk kit?
