you do not need special mounts. you, however, need to use the ones for the 93.
also if he intends on using the hydraullic trans he will need a conversion kit and there are a couple compnaies that make them such as
- innovative and hasport
or he can swap the hydro to a short geared ys1 cable tranny found on the 92-93 gsr's
no problem i think that there is another link to a different company but i haven't found it yet...
i think that it was hondapartshero (all one word) and it was an ebay store
i believe that you are going to also have to run wires if you use the stock intake manifold, due to the fact that the early gsr's had secondary butterflies....
