95 GSR problems
Discussion in 'General Tech and Maintenance' started by ep3kid510, Oct 10, 2006.
  1. ep3kid510
    ep3kid510 New Member
    so I was driving around and took it to about 6krpms then suddenly I started losing power, tach kept goin past 7k but I was slowing down still. Then i slowed down next thing you know the car stalled.. :confused: I noticed the oil level low indicator was blinking so I added about 2.5 quarts. Next I did a compression test, all cylinders came up to about 185+. Started it back up then the motor started making this "clucking" noise. At first it only happens when Im not pressing on the clutch. Now it makes that noise at idle. I drove it home but I kept stalling (shit was hella loud) the only way that i could make it go was to keep my foot slighty on the gas while I start it. Anyone know what could be my problem?
  2. f22b1 coupe
    f22b1 coupe Junior Member
    Indiana
    Haha, well, I'm not sure that is an "add oil" light so much as it is a "low oil pressure" light. Sounds like a blown head gasket maybe.
  3. ep3kid510
    lol I work on F-18 hornet. Thats the warning I get whenever im troubleshooting the jet. Anyways, im a noob when it comes to cars
  4. GSRCRXsi
    MD
    sounds like you starved the engine of oil, revved it out when you had no oil pressure and now you fucked your bearings and your knocking. sounds like its time for a rebuild
  5. ep3kid510
    that's what i thought too.... btw, how much does it cost for a rebuild?
  6. myah
    myah Neu Impact Performance
    ks
    ok dosen't sound like you need a rebuild you should check your map sensor cause thats what was happening to me the stalling part and i replaced my map sensor and the problem was gone
  7. ep3kid510
    will do... but whats up with this clucking noise coming from my valve cover?
  8. myah
    ks
    have you check your valve spring yet make sure that their are torqued to the correct torque and i think that should solve your problems and check your time belt
  9. GSRCRXsi
    MD
    umm valve springs dont get torqued at all. wtf are you talking about? they are held on the valve by little valve keepers.
  10. myah
    ks
    ok shit my bad i was looking at new valves when i wrote this shit my bad i said valve springs fawk
  11. ep3kid510
    aight, Im gonna drain the oil, refill it back up then do a compression test(again) then im going to get my valve adjusted. If that doesn't work...eh whatever. Let's see what happens.
  12. FlyBMXer4130
    FlyBMXer4130 Sh1tAssIntegras
    New Orleans "little mexico"
    I just recently had the exact same problem with my '91 Integra, no clue on what it was, at first I changed distributor/spark plugs and it ran better for a week or so, then while driving one day on interstate 70mph, let off clutch to coast and engine died, would turn back over after a minute of sitting, smelled & heard something under hood, timing belt was being torn somehow but still had tension... when I replaced the plug wires, it started up didn't idle had to gas it, and leaked all oil out immediately when turning over... been having no clue where to go from there except B18C1 it... 'til the $ comes in what to do???
  13. D See 2
    D See 2 Senior Member
    Baltimore, MD
    Your compression readings tell you nothing about the condition of your bearings. Don't waste your time again. It's definitely a rod bearing that has been spun. Like Ian said, time for a rebuild. This is what happens when you run out of oil.
  14. ep3kid510
    yeah thanks bro, but you think buying a head will fix it?
  15. D See 2
    Baltimore, MD
    No. The problem is your connecting rod bearing(s) in the lower end. You can't just replace them. At this point, you'll need to take the block to a good machine shop and have them assess the situation and determine the next steps. It will depend on the severity of the damage.
