95 H22 Into A 96 Accord
Discussion in 'HYBRID -> BA-BB /CA-CD' started by STEVECONLEY, Mar 12, 2003.
    STEVECONLEY Junior Member
    ok let me start off. on a p-13 ecu the pin outs on bank A has 26 pins right and the top row is odd and bottom is even, for an example A1,A3 etc on top and the bottom is A2,A4 etc. if i'm right here is my question. we have the skunk2 conversion harness obd2 to obd 1. and the swap says to switch wire's a6 and a11 going into the ecu. well on the skunk 2 harness there is no wire going into a11. what do i do, and i also have to add the iab, knock, and both of the vtec wires. could i just follow the pin outs on the ecu and cut the wire in the middle of the skunk2 conversion and wire it from there? please help guys!ohh and if you didn't read the topic this is a 95 jdm h22 into a 96 non vtec accord.
