95 hatch, b18c1 jdm engine
Discussion in 'HYBRID -> EG-EK / DC' started by VTECPOWER, Apr 7, 2004.
  1. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    I would like to put a jdm b18c1 engine into a 95 hatch which is an Si
    I am probably going to order the complete changeover from HMO
    What else do i need for this swap?
  2. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    nothing, the complete changeover comes with everything you need to do the swap- you'll have to keep two mounts from your old si motor and teh shifter, do a few wiring mods and you're set-
    http://www.c-speedracing.com/howto/b18cswap/swap.php
    go there
  3. VTECPOWER
    Winchester, VA
  4. B18Civic95
    B18Civic95 Member
    USDM is b18c1 JDM is b18c. I would recommend you running your p28 Ecu you currently have in your si. I you want the p72 USDM gs-r ecu we could trade. I have it chipped and upgraded by Erick's Racing. The complete changover must include Motormounts, Shift linkage, Axles, complete engine with tranny, manifold, distributor, and harness. You don't need the ecu
  5. VTECPOWER
    Winchester, VA
    what's the significance of the p28 over the p72?
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    The P28 is the D16Z6' ECU, commonly used in swaps because it is easy to chip to run pretty much any motor. The P72 is the stock GSR ECU, and controls all the normal functions including the IABs. There is no significance over the P72, unless it has been chipped to run a GSR properly.
  7. E_SolSi
    :concur:
    most P28 chips do not set it up for IAB control
    so unless you are running a skunk2 manifold that does not have IABs it will not run properly
