95 hatch/gsr Wiring question
Discussion in 'HYBRID -> EG-EK / DC' started by hondapop, May 31, 2005.
  1. hondapop
    hondapop Junior Member
    Can someone please help me with a wiring question in the engine bay. I am in the middle of a GSR swap into a 95 cx hatch (both obd1). I have most of it worked out except one item that I can't find in any of the posts. I plan to change the ecu to the gsr ecu and run the vtec,knock, ect wires out to the three passenger side plugs. My question is...can I use the GSR engine wiring harness instead of the civics? If I use the civic's I'll have to change a few sensor plugs and run the vtec, knock,etc sensor wires past the three plugs to the sensors. If I use the gsr engine harness I will only have to run the 5-7 wires to the three plug on the passenger side. Does this sound correct and is there anything wrong with this approach...tks for your help....
  2. doubleE
    doubleE Junior Member
    I recommend the GSR wire harness since your engine and ecu are both GSR. What three plugs on the passenger side?
  3. hondapop
    The gsr harness has the plugs backwards to the civics since it is a JDM (the three that go to the ecu are on the drivers side on the GSR). It appears that I can remove the engine harness and re-install with the plugs on the correct side (and all the plugs will reach each sensor). Does this sound like it will work? tks for your reply...
  4. 88bluehf
    88bluehf Senior Member
    Denton,TX
  5. pissedoffsol
  6. hondapop
    Thanks for the replies...This is a tough topic....I have about 50% replying to use the civic harness and 50% say to use the GSR (I have this question on three other sites). Hate to beat a dead horse but can someone tell me why I shouldn't use the GSR harness? Simply stating "use the civic harness" doesn't help much...no offense intended since I do appreciate the feedback....
  7. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    Just Use The GSR harness and use the link that Pissedoffsol posted..It has a lot of info...READ!
  8. hondapop
    Thanks your "explanation" has been a big HELP!
