95 ls into 92 si hb
Discussion in 'HYBRID -> EG-EK / DC' started by Kromesurfer, Dec 19, 2002.
  1. Kromesurfer
    Kromesurfer Junior Member
    So I read that you were told that there needs a mounting kit and then you do not need one. I was told that it is better to get a Hasport kit with the eurothane bushings. Also that the trannie needs the mount out of the LS or the Hasport kit http://www.hasport.com Hasport.
    :D
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    5th gen's do not need mount kits for a b series,you can use the motors stock mounts.You can get the hasport ones if you like but they aren't needed.
