95 teg junker i found
Discussion in 'Civic and del Sol - EG and EK' started by sufikation, Jul 16, 2008.
  1. sufikation
    sufikation Active Member
    Fruitland, ID
    so i found a 95 integra with a b18b1 and what not in it. im taking the motor and rear disk brakes...what else should i snag to complete these swaps to my 98 civic hb?
  2. efhondakid
    Akron-Canton, Ohio
    If you get the entire swap and the rear disc setup, Id say youll be set.
  3. sufikation
    Fruitland, ID
    i guess im not sure what the complete swap is...any help there??
  4. efhondakid
    Akron-Canton, Ohio
    Motor, tranny, axles, wiring harness, and ECU.
  5. sufikation
    Fruitland, ID
    nice...i will prolly skip the brakes for now. i want the motor in a bay way.
  6. efhondakid
    Akron-Canton, Ohio
    I just noticed that the motor is OBD1 and your car is OBD2, youll have to do an OBD conversion too.
  7. sufikation
    Fruitland, ID
    great looks like i got some forum research to do. }=)
  8. Kovalski
    Kovalski New Member
    Ontario OR
    LOL..Peediz..C if u cant just get the whole car for 100 bucks..than u will have all u need but the oBD2 stick..I wish u the best bro..I will be there to help.:) Kov
  9. eg6sir
    dont forget the shift linkage
  10. sufikation
    Fruitland, ID
    thanks for the great input everyone. }=)
  11. awptickes
    MD
    if you get the brakes, grab the master cylinder too.
    EDIT: and proportioning valve.
