95accord Lx F22 To H22
dhaccordLT-R
i am swapping my stock f22 to a usdm h22 and was wondering, since my car never had vtec( its an lx), will i have to worry about any additional wiring etc.? Same for the knock sensor? i noticed that the h22 has both the vtec and knock sensor where i dont. will the h22 accept the accord intake?
Yes, your Accord intake should work(mine did, however I have a Euro R so the manifolds are different).
Since you have an LX, you'll need to run vtec oil pressure switch, vtec solenoid, knock sensor and I think one other thing that I can't remember right now... :)
I haven't slept in a very long time....
It's not a difficult wiring setup unless your OBD versions don't match... i.e. you have an OBDI car 95 Accord, and your engine should be OBDI(95 or older)..
If they match, wiring is a snap, even running the wires isn't that difficult...
thanks, I knew I was forgetting something! :) It's also known as the IAB(Intake Air Bypass) which, in my opinion... is the suck.
