95EGCoupeVtec
SOHC VTEC at its best
as the title states, i have some stuff for sale.
d16z6 head, has obd0 injectors on it right now that can go separately, and also a intake manifold, idk what obd it is.
a h22 jdm auto ecu
jdm obd0 b16a ecu manual
17" black wheels
p06 obd1 ecu
i also have oem obd1 injectors off of a z6
60 trim .48 ar T3/T4 Turbonetics turbo with a polished compressor side and 5 bolt exit, including all the bolts to bolt it to turbo, for downpipe, and for oil drain and im including a restrictor from turbonetics on it too. the turbo does need new seals. it hits 8psi around 4k on my z6 and spools pretty hard when i had it on my car
a 4 psi 38mm tial wastegate spring
a manual boost controller
a short shifter
and oem integra gsr springs that will fit on a eg/ek civic or 94-01 integra
i also have 2 front civic springs and struts that are together that don't include the lower forks that bolt to the control arm
i have a d16z6 auto throttle body
a fast idle thermo valve
a oem intake for a z6
and a brand new 89 - 91 civic/crx si iacv valve
I also have a d15b7 head that is basically just the head, no valve cover
I am located in Carriere, MS, zip code 39426. if you need pictures of anything let me know.
a h22 jdm auto ecu
17" black wheels
p06 obd1 ecu
a short shifter
