95obd1 f22b1 n a 96 accord
Discussion in 'Accord' started by ziggyb20b, Jun 30, 2008.
  1. ziggyb20b
    ziggyb20b New Member
    convert 95obd1 f22b1 to obd2???
    :(i have a automatic 96 accord & the original motor burned up i put a 95 f22b1 n it & changed the oil pump 2 except the C.P.S. but i dont have a crank pully from the org. motor im told it should have a ring on the back of the crank pully that the position sensor reads! either way im getting no trouble codes & no fire but i am getting power 2 the coil i dont understand!!! if anyone has a pully or knows what is wrong your HELP is much apprciated... thanx ziggyb20b
