96-00 side mount
loko123
hey just wondering if i could use the stock side mount on a 97 hatch to fit in a b18c1? and if i change it to an aftermarket do i also need to change the motor bracket that is in the motor?
what the hell are you talking about the radiator? It sounds like you have no clue what your talking about and have no knowledge of what you want to do. Research there are plenty threads on motor swaps. then come back to use when your stuck and cant find a answer
did i mention radiator NO i think your the one that is lost donkey!! i'm talking about the motor mount
yes the stock one will work but the b18 has more power than the stock d. my experience was there is lots of movement from the stock so i would recomend upgrading. the stock motor bracket works fine with my hasport mount
