hello I Need Help. I Have A 96 Accord That Has Factory Installed Power Sunroof. The Roof Just Stopped Working. I Press The Button On The Dash And Nothing Happens. I Checked The Fuse And It Is Fine. What Should I Do. Should I Change The Dash Switch And If So How? Also Are There Any Relays Or Circuit Breakers That I Should Check. I Have No Idea About This Sunroof Other Than Where The Fuse Is Located. I Have A Haynes Repair Manual But It Is Absolutley Not Helping.
