96 B18B1
Discussion in 'Engine Building' started by korey, Mar 17, 2004.
  1. korey
    korey Senior Member
    OREGON
    Does anyone have any opinions on any good lightweight flywheels? Brands, pros, cons, etc. Let me know, thanx.
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    what application-D,B,or H series? NA/FI? budget. give us a little more to go from.
  3. hybrid89
    SoCal
    sorry my bad. (96 B18B1). If it is all motor, I recommend staying with a 12lb. or so. If you go "too light", you could have idle issues when you come to hard stops. Hell thats still 10-12 lbs. lighter than stock. as far as brands-ACT,fidanza,Clutch masters. they are all about the same, until you get into Toda/Jun for more money. I sat ACT for the price and product you get.
    matt
  4. korey
    korey Senior Member
    OREGON
    Thanx. Yeah sorry, it is my N/A B18B LS. So, you recomend staying around 12 lbs.?
  5. hybrid89
    SoCal
    yes. I am running an 12.5 lb. ACT Streetlite disk. nice product and decently priced. hope this helps,
    matt
  6. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    you could just take your stock flywheel and have it lightened at a machine shop. probably save you alot of money compared to buying a JUN or Toda flywheel.
  7. hybrid89
    SoCal
    as long as they rebalance it, you could go this route also.
  8. Tim@Canspeed.com
    Tim@Canspeed.com Member
    The ACT is good choice and affordable at the same time.
    A machine shop wouldn't be able to take as much wieght from your stocker as the aftermarket one is lighter.
