96 Civic DX
Discussion in 'Civic and del Sol - EG and EK' started by MoSeS, Aug 15, 2006.
  1. MoSeS
    MoSeS New Member
    Ok, I want to pretty much make my dx Civic into a Si. What can I use from the suspension and does the Si have rear disc brakes and will it swap over into my dx? What else will swap in without much fuss? Let me know.
  2. nulowz_uncivil
    nulowz_uncivil New Member
    Fort Meade, MD
    you'll need the full rear susp. and e-brake cable(s) also are you going to swap in a B16? gauge cluster will swap, everything will swap depending on your knowledge and ability.
  3. MoSeS
    MoSeS New Member
    is it disc brakes with the four lug pattern? also i was planning on putting in a b18 or b16, whichever one gets to me first.
