96' Civic LX - What do I need to do to go to V-Tec?
Discussion in 'HYBRID -> EG-EK / DC' started by NeoTokyo, Jan 18, 2009.
  1. NeoTokyo
    NeoTokyo New Member
    Hey everyone;First time post, first Honda.I have a 1996 Honda Civic LX auto 4-door (non-V-tec of course) and wanted to know what I had to do to swap a V-Tec engine into it. What wiring, ECM, Sensors, cooling, trans, mounts, accessories and so on do I need to change and buy? Is there a guide out there?The engine would be from another 96-00 Civic. Is there a better engine option that is still cheap and easy? Other V-Tec engines??? I know I need to keep it to 96+ for legal/smog reasons.Reason for swapping engines, the 210k engine is burning oil bad (1qt a week,) I would rather just swap engines for a lower mile one.As for working on cars, engine swaps are no stranger to me, I just hate wiring is all... The easier the better when it comes to wiring.Thanks everyone.
  2. stev0_wic
    stev0_wic New Member
    connersville, IN
    It all depends on what kind of motor you want. The easiest/cheapest swap you could do is another single cam D-series swap like a D16Z6 or a D16Y8, or you could go for the dual over head cam LS swap or GSR. You will have to decide which motor you want, which does not have to be from a 96-00, or even a civic for that matter. Then you will need the wiring harness for it unless it is an OBDII like your car is. There actually is a honda motor swap guide book that they sell at Autozone. It might be able to help you with the wiring problem.
  3. murray195
    murray195 Member
    Calgary, AB
    The D16Y8 would be a fairly straight forward swap. You just need to run two wires to your ecu. A wire from your oil pressure sensor and a wire from your vtech solenoid, and ground the ground.
