96 civic si coupe d16y8 ej8 upgrade ideas
Discussion in 'Engine Building' started by 96 civic coupe D16Y8, Nov 16, 2013.
  1. 96 civic coupe D16Y8
    96 civic coupe D16Y8 New Member
    Hi all this is my first post and in new to the site any help would be greatly appreciated, in trying to get some tips on how to upgrade the performance of my 1.6 sohc vtec all stock atm. Please advise.... Thanks :)
  2. E_SolSi
    what are you looking to get out of it?
    what is your budget?
    how mechanically capable are you?
    what are your long term intentions for the car?
  3. 96 civic coupe D16Y8
    Daily drivers car, stage 2 ish possibly boosted, 3k, will be undertaking all the work myself
  4. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    And your experience level is??? Don't be shy, everybody has a starting point. :) Also, what about shop space and tools, etc.
  5. E_SolSi
    being that "stage 2" doesnt actually mean anything
    please be a bit more specific
  6. 96 civic coupe D16Y8
    fast road cams (stage 2) first engine internal modding car messed around with quite a few cars when i was younger 15ish bit first serious project. Thanks for your responses
  7. 96 civic coupe D16Y8
    can replace brake discs and pads and various ancillaries but not much experience
  8. 96 civic coupe D16Y8
    i dnt want to see swap the d16 eng. Just "enhance it" thanks for any i
    advice
  9. 96 civic coupe D16Y8
    to clarify my terrible previous post, i don't want to swap the d16y8 lump just maximize its potential
  10. Dual-500
    Fort Worth, Texas
    And you have basic or entry level experience. :). That's just fine and it showed via your questions and comments. What about tools and a work area?
  11. Matts96HB
    Matts96HB . Moderator VIP
    If it's a daily driver, you're pretty limited in things you can do to it. Your basic bolt-ons would be the wisest place to start.
    Intake, header, decent exhaust would be a good starting point for the engine. Upgrade the brakes, suspension, wheels, tires, and learn to drive your car. Consider it "getting your feet wet" :)
    Adding an aftermarket camshaft is pretty much a waste on a d16y8. The potential gains just don't justify the cost/work (to me, at least.)
    Turbocharging a car is a whole different animal. Even if you leave the engine components stock, the addition of the entire turbo system adds plenty of new places for failure to occur. Since you have very limited experience modding and working on cars, I'd advise staying away from forced induction for right now.
  12. 96 civic coupe D16Y8
    ok thanks for your honesty and opinions, i have access to a wide array of tools and decent sized work space. Gonna start of with exhaust system and manifold, is it worth polishing the ports while there open? Then Il look into the induction aspect, what would you recommend? Thanks for sharing your expertise i am a novice after all
  13. Dual-500
    Fort Worth, Texas
    Don't polish ports - years ago that was done, now more is know about the flow and it's frowned upon. Match ports, de-burr ports, don't polish.
    For a $3k project - don't put it all into the engine. Suspension, strut tower bars, sway bars, struts, wheels, tires, brakes. Suspension, wheel, tire, brake improvements also make a car more fun to drive. Also, you I would suggest you consider re-bushing the suspension with polyurethane bushings. Replace exhaust hangers with polyurethane type with doing the exhaust system.
    BTW - how many miles on the short block? What about clutch and pressure plate?
  14. 96 civic coupe D16Y8
    just rolled over 11000 miles on the original block as for the clutch its original oem one, as for as the wheels and tyres go atm its only got 185/60/14s on what would be the optimum size as theres a not a great deal of clearance at full lock?
  15. Dual-500
    Fort Worth, Texas
  16. 96 civic coupe D16Y8
    thanks had a look through the post as mentioned above Ive got a few ideas Il update and post some pics in the next few days
  17. 96 civic coupe D16Y8
    also rear disc conversion? Any tips on were to look? Many thanks
